Four Wheel Campers Gallery
DirtyDog
Captain Leisure
Site Team
Nov 10, 2005
3,157
Eugene, Oregon
There is now a gallery dedicated to Four Wheel Campers:
http://www.wanderthewest.com/forum/index.php?app=gallery&module=cats&do=sc&cat=124
Note that if you are a contributing member, you will get points for posting photos in this gallery.
Cheers!
JJAv8or said:
Can you make the link on this thread active ??
The link to Contributing Member Rewards doesn't work because the "rewards" program was abandoned when DirtyDog sold WTW to new owners a year and a half ago.
So...I suppose that first post should/could be edited to remove the irrelevant link.
When DirtyDog owned WTW, points were awarded for posting photos to certain galleries and you became a "contributing member" for doing us. DirtyDog also offered rewards for having points, including for a time a monthly drawing. This is no longer active and I do not know if the current owners have plans for reactivating any of this.
veopTCyDkEBy6zj5A
AF1QipNXflGO778U0AslQdJe5H4c234i8RJUioLthf2uqw2yv-bRQzEDAAc7406SDtYljQ
wxOmhTfMI7MEuLBLHxbbusie0OBqYvZ7WdqT7l5CD0dn1IacX2yAaYdhq9A2NbAxWFhh2wU0T_jQC8OBNiKRrG3Q2qAFpaKNqK5z62cSLKAAL4tKKjkF0S0YbsVbsJSGeooBshIs9R5PZTJevhOzSclXJYmmTd3j_GFpUcJOVqpyvA_GQ6nhkGayc_omb0ulvhaqFJcI00v5S6OPPSJ8-xKXotuys7sGNAF0k4qfzs99ESSnssi8PMVx1Jm2h85V8FOxCKlTcQs_UKONN_EvYFFbhGn80_pEMp37L-IoZNwKEVdNX9wCNkT2fMDxkGraENnFqrYTxkNp1Pu8hjT3DgAWiD96QmdD3881959TGNFk_Eyi4PQeGkeBn8LctMkMT97OVt_Pum586gmeuzN1_7pXwrJiRasmhM-ks-1oTEbZOf6qkUnwyiqpRtfrTzMXd0pKhcJi86ff2pBtdK_JKumgeGwekRZ64WSz94tcPMnd1LA_4zHgirvGqwfASugyjSI-IEdH-IcmjRFFeOfFbwKSvt4CzFKF8m62dfXZuG5JEpPtBgdWK-j6Aslx8zctCVidmOn0u7ZcgpsyqWTbf7xiXXGJr92k2uMeQBqosFrlT3VclHyRpVeKAdxMtBLGM7hgRs_i8Vnz_u-WOFvuPf8Qf0vSXCwh8dtdrrDRWneDzYI=w1550-h872-no
Random pic test without Photobucket
Carter Ferry on the Missouri River, MT
veopTCyDkEBy6zj5A
Just picked up my new Hawk Woolrich Edition one month ago. Getting ready to take it on its first shake down trip.
2017 Ram 2500 4X4 Cummins 6.7 Crew Cab Auto Level Rear Suspension
JDean requested some FWC interior mod shots- mine is certainly under the "Quickndirty" category. It began as just pulling the furnace for a bearing shriek.... the floor was rotting away. The siding was in trouble. That corner jack was waaaay too wobbly. Front overhang bed platform was rotten etc etc [bet somebody else here knows this drill LOL!] So ...I had 1" blue foam to replace insulation. 1/4" ply left from the catamaran project [non marine grade - quit salivating] some gray paint from a rental repaint and a bunch of 3/4" SD self tap screws. yee hah. tgmorrisey and shellback were some of the inspirations - my level of finish is much more on the get er done side of the equation. ....
this coming week I will install lifting struts [installed some ancient military grade PV panels on the roof- its now officially "a grunt" and screw and glue some polyester coated vinyl wrapped around each corner - in keeping with my quickndirty theme, these will be glued to the old vinyl and then I'll cut out and discard those moldy lookin areas....here are some more interior shots:
Thanks again, Mack. Appreciate this a lot. I've actually been giving a lot of consideration to doing something very similar with the fridge, so it's great to see something besides my imagination.
Got this about a month ago: ‘79 FWC Wikki-UP model, Chevy 1 ton 4X4. Camper interior is mostly gutted so we have a mostly clean slate to work with. Looking forward to getting it together!
That thing is so freakn rad!
1979 FWC Fleet
Got this a few weeks ago. Drove from a tiny town in NorCal to an even smaller town in Washington and got it from a really cool guy.
Have mostly finished cutting the inside and painting quite a bit of it. Have prepped And painted a lot of the trim and latches on the outside and waiting for the waterproof bedliner paint to come in so I can finish the outside.
Baja trip in early November so lots of work to do!
I have a running thread on here and on one on the FWC Facebook groups. IMG_0934.jpg
Just picked up this Hawk in Bozeman last month. Broke it in on the way back to the west coast, in central Washington.
