Fridge Draining Battery
CPT Davenport
El Pescador
Dec 18, 2021
716
Davenport CA
Not quite sure where to post this, but will start here. We just returned from the mountains with temps over 100*F. My 85 liter, 2 way fridge was working overtime. 206ah lithium battery was getting down to 43% by morning. In the past when camping in the dessert with high temps, the solar would keep up fine. While camping in the trees of the mountains, not so much. I still have yet to add my DC/DC charger, but in this case it would not of helped. We set up camp and the truck would not move for 5 days at a time as we explored by boat.
- I ran the fan for the fridge. Does this really help, or is it just further draining the battery?
- The items in the door of the fridge felt warm to the touch even when set on the highest setting. I feel the lack of insulation in the door is where I was loosing most of the coolness. One thought I had is to not store items in the door but instead add foam insulation on trips like this and sacrifice the storage space.
I have an extra latch installed to make sure the door is closed as tight as possible. We also kept frequently used items such as "refreshments" on ice in a cooler so the fridge was only opened a few times a day.
Any other suggestions to give the fridge some relief on trips where the camper sits for days and only is getting 3-4 hours of sun a day?
My solar is 175w on roof with aux 135w panel plugged in the back port.
Not sure this will help but can't hurt. I have 200 W BB batteries with 300 watt solar. Went on a trip and was somewhat cloudy. Not super hot but 80's (that's hot for an Irishman)... gotta keep me beer cold so had 2 way Isotherm on 5 (outta 7). Next morning I was down to 60% !! I have a DC/DC charger as well. Discovered that on rough road the wire to the controller to battery was semi tight but not really.... the wire pulled out with a gentle tug. (It is the only thing I don't like about the Victron ... terminals should be a bit more robust) SO.... just saying... check all the connections first before playing with the fridge. I thought my fridge was overworking a bit as I had started it up fast instead of the way they suggest. ... Sure enough the loose wire was the culprit.
If your system wiring checks out OK I recommend replacing your current solar panel with the largest single solar panel that will fit on the roof of your camper. Unfortunately you may have to also upgrade your solar controller to accommodate the larger panel which is likely 24, 36 or 48 volt (the Solar controller model needs to be able to accept the higher voltage and put out the 12 v needed for your battery system).
In 2018 I replaced my two 100 watt solar panels with a single 360 watt residential type LG solar panel. The new panel was less cost than the combined cost of the two 100 watt panels and it is slightly lighter in total weight, when also considering the mounts and Y cable connector between the two panel system, as well. I did have to replace my Victron 75/15 solar controller and I went with a Victron 100/30 controller. I think there are now panels over 400 watts that have the same footprint as my 360 watt panel.
We have done extensive multi month trips with this system and I no longer need to have the camper connected to the truck and only plug into ground power when it is convenient or when we camp in a shady place under trees.
I camp in Northern Minnesota under heavy forest canopy. For these trips I carry a 1000W inverter/generator and a 12V 35A charger. An hour in the morning is usually enough to see me through the day. I still get a little charge from the solar. Haven't camped in 100º temps (never, I hope) but I would run the generator again in the evening if necessary.
200W solar, 210AH CG2s.
Cpt Davenport said:
. . . I ran the fan for the fridge. Does this really help, or is it just further draining the battery? . . .
I am assuming you mean a fan removing the hot air from behind the fridge? You should check to see if it is doing an adequate job. I periodically check to see if the air back there is at or only slightly above ambient.
I try to keep the sun off the refrigerator side of the camper and off the refrigerator inside (my refrigerator is right next to the back door).
I also periodically check the inside temperatures with a infrared thermometer to make sure things are in the safe temperature zone.
On my current fridge the coolest part of the door is the rubber gasket sealing the door.
Thanks for the input and suggestions y'all. More solar, more battery storage or a portable outside power source would help. I just feel the Isotherm is under insulated. When only opening 3-5 times per day it should be able to retain its chill. My cooler can hold ice in those temps for five days and that is with frequent opening throughout the day. Agreed that parking with the fridge side away from the sun helps a lot. Yes the fan I'm running is the one behind the fridge. I'm thinking about also running the roof fans on low and venting with my turnbuckle doors when we are off away from the camper for the day. My only concern is will the extra juice used to run three fans save juice by keeping the fridge from working so hard? The whole thing boils down to the fridge not holding the cold good enough.
I freeze 1 gallon jugs of water for my cooler and drink when they thaw. I may try to insulate the fridge door and put a frozen water bottle in. I will have to then limit what perishables I bring to compensate for the loss of space.
Another possibility is to put frozen blue ice packs in the freezer compartment. Buy a smaller YETI cooler to store your veggies etc. in while you are away from the camper & cycle the blue ice containers between the Yeti & the fridge early in the day to allow them to refreeze while solar is at a maximum & the fridge is running anyway.
Alternatively, buy block ice for the Yeti when you are traveling. It sometimes just takes experimentation to make improvements in ice management to meet your needs. We have also used dry ice wrapped it in newspaper or cloth to extend its life when available.
I have the 130L TruckFridge and added an inch of foam insulation to the top, bottom and back of the fridge. I would have done the same to the sides if it wasn't such a tight fit. I also pay attention to sun direction when parking and usually park with the back facing north in hot weather.
Keeping the fridge fully loaded with pre-cooled food and drinks creates a large thermal mass that maintains temperature better. I also keep some frozen water bottles in the freezer compartment which reduces the compressor cycling.
+! to that. Leave as little space as possible... frozen half gallon jugs of water last a long time and thereafter drinking water.
Keeping direct sun/heat off the side with the refrigerator makes a BIG difference. I just returned from a wonderful father daughter trip in the Painted Hills, and the first night was brutal. I parked with the refrigerator facing west. My thermostat controlled fan kicked on about 1:30 PM and ran until 10:00.
I repositioned so the refer was shaded in the afternoon, and the fan never came one. That said, the refrigerator kept things wonderfully cold. The fan is very helpful!
I have always kept the fridge stuffed to the max thinking the same thing. I did just watch a video that explained the need for some space around the edges in there so the cool air can circulate. This was for an absorption style fridge. I wonder if the same need for circulation is present with the compressor style.
I think that facing the fridge side of the camper away from the sun is the most important part. We set up on the lake with fridge on the north side. Even though we were only getting 3-4 hours of full sun on the panels the fridge and battery kept up way better. When we left the camper in the parking lot of another lake, because of the boat trailer and oneway situation, we were forced to park with the fridge facing SW. Even though we had sun all day on the panels, the all day sun on the fridge side was our demise. I'm looking into some kind of shade to deploy in these situations.
I store my collapsible grey water jug and hose in the side compartment were the fan is. I think this is limiting the circulation and also part of the problem. I will relocate these items.
Air is what does the cooling of the contents of the fridge: air is cooled by the heat exchanger (evaporator coils), circulates past contents removing heat. So there needs to be room for air to circulate past all the contents of the fridge.
Some guys add small muffin fans inside to help this process and to equalize the temperature in the fridge.
I know it would not look great, but would putting something like a 1" thick piece of insulation on the outside of the refrigerator door help? This way you can still use the door storage and add insulation to a poorly insulated side of the fridge. Maybe glue a piece of corkboard to the fridge door and use it as a bulletin board, or something to that effect.
Good ideas Ted.Duel usefulness. I like that.
Great idea!
JaSan, et. al.
I know that a residential type refrigerator with a freezer needs to allow internal air circulation from the freezer compartment to the refrigerator compartment but I am not convinced that is necessary for a 12 v refrigerator that does not have a freezer compartment.
The small volume of a 12 v refrigerator compartment is cooled by the compressor system and in turn the contents will cool by convection and conduction. Unless the small volume food compartment of the 12 v refrigerator is stuffed so full that no air can move (which would require something solid or nearly solid) I suspect there is plenty of air space to allow for convection to occur. In addition the food would be in contact with other cold items and would cool by conduction which is a superior heat exchange mechanism in air.
I confess that I am no expert on this so if you have a reference you can share to help my understanding of why a fan is needed inside a 12 v refrigerator compartment I would appreciate you posting a link or sending me a PM so I can read it.
Thank you
Craig
Craig,
The only test I know of was done by a guy going by Sternwake in the old Cheap RV Living web site about 8 years ago. I don't remember the model of upright RV refrigerator he tested. The web site has changed owners and name (currently vanlivingforum.com). My testing followed his except for the addition of fans (I'm going by a very creaky memory here).
My testing was as follows:
Norcold DE-251D 1.9 cu.ft upright loaded with 12 oz water bottles, cold soaked for 24 hours. Fridge temperature set to be ~34ºF. Internal temp variation was about 4ºF.
Temperature was measured with a IR temperature gun; each water bottle measured in situ.
External refrigerator temperatures were also measured: door, door gasket, door frame, sides, top, bottom, back behind condenser.
Test was run twice. I don't remember the ambient temp but it was run in winter, in my basement so probably ~68º
Results (as I remember them):
Coldest water bottles were in the rear bottom of the refrigerator and in the top left (right next to the freezer).
Warmest were in the top door shelf.
There was ~8º difference in temperature of the water bottles.
Exterior sides were all about the same temperature with the top left being the coolest of the sides (close to heat exchanger).
Rear exterior was the warmest (behind the condenser).
Front door was at about the same temperature as the sides (I did add a plywood facia to replace the metal door skin).
Door frame and rubber seal were coolest of all external surfaces (leakage?). The door eventually did warp enough to require pinning at the bottom.
Both my refrigerators (Norcold and current cheap dorm fridge) have tiny (and almost useless) freezers so didn't test freezer-less refrigerators.
I don't think conduction has much cooling effect as there is little contact between the odd shaped items in the fridge. The only real surface contact is on the bottom where they rest on another surface. Air to item convective heat transfer is the main mechanism. There should be sufficient air circulation unless things are jammed tightly.
JaSAn,
Interesting test. Thanks for sharing.
It seems that the closer the items are to the heat exchanger the colder they are.
Conductive heat transfer through the sides, door and seals for sure. You did not say what the temperatures were of the various exterior surfaces of the refrigerator. I would be interested to see the data if you still have them and would share.
It does appear convection is cooling the interior contents and there was plenty of room for unassisted convective air flow. Coldest at the heat exchanger and at the bottom below it. The cold air is heavier and drops to the floor setting up the convective air circulation.
The warmer items appear to have been closest to the sides with the most conductive heat loss (i.e. those without a heat exchanger).
Did you measure the temps of the interior walls, floor and door surfaces? That would be informative.
Did you run the test with and without a fan inside?
Since there is clearly convective air flow I am wondering how much difference the fan would make. Seems to me the temperatures of the contents might get closer together and bring all of the contents closer to the average temperature (slightly warmer for the items in the back and slightly cooler for the items in the front). I do wonder if the little bit if heat from the fan motor would raise the average temp a bit.
Looking at my own Norcold refrigerator and my dometic portable 12v refrigerator I see that the heat exchanger plate in the Nordcold is small relative to the total interior surface area. Also it is at the top of the back wall and there is a small freezer so the refrigerator works just like a residential type refrigerator where there has to be a path for cold air to flow out of the freezer into the refrigerator compartment.
The surface area of the walls in my Dometic cooler is much less but I think the cooling surface is in the vertical wall of the step of the interior compartment over the compressor. Some models may have a cold plate that wraps around the sides of the larger compartment and I know that one model has a separately controlled cold plate in the bottom of the compartment over the compressor with an added ice maker compartment. The sides of the box (under the exterior cover) are covered by industrial foam insulation so it is better able to keep up with the conductive heat loss through the sides and door (top door) of the refrigerator). The contents of the dometic fridge also seem to have less variation in temperature.
I do not know what the difference in insulation may be between the Norcold and the Dometic fridges and if that is also a factor in the heat flow through the sides but area wise the ratio of cooling plate to interior wall surface is much more favorable in the Dometic portable fridge than it is in the Norcold built in fridge.
130L Truckfridge in my rig. I added a small squirrel cage fan inside my fridge that runs whenever the compressor is on. It is positioned between the small freezer compartment and the top inside of the fridge next to the compressor indent. It keeps the temps more consistent in our fridge, as evidenced by less frozen veggies in the crisper (bottom) and colder beer in the top door compartment. Readouts on the temp sensors are more consistent too.
fan i used - Vic's Puma (Grandby) build - Gallery - Wander the West
ckent323 said:
. . . You did not say what the temperatures were of the various exterior surfaces of the refrigerator. I would be interested to see the data if you still have them and would share.
Did you run the test with and without a fan inside? . . .
I did measure surface temps (inside and out) but I don't know where that data is (if I even kept it). This test was done 7 - 8 years ago. I did add 1" formular around the sides, top, and bottom (on the Norcold).
I did not use an interior fan. I had planned on installing one but my supply of round tuits has been depleted for some time.
ckent323 said:
. . . I do not know what the difference in insulation may be between the Norcold and the Dometic fridges and if that is also a factor in the heat flow through the sides . . .
I would guess there is some variation in the insulation and thickness among makes, models, and years of refrigerators. Each manufacturer would have their own spec on insulation effectiveness.
This experiment is so easy to do and there would be variation among refrigerators. I should do it on my current dorm fridge. The outside temps might not tell much because it uses the skin as part of the condenser.
