Josh41
If I buy a shell without a furnace can one be added?
How about the folding bench?Josh41 said:If I buy a shell without a furnace can one be added?
Josh41 said:How about the folding bench?
I didn't see any with the Wave but it was in a hard side trailer. I run the hose into the camper through the turnbuckle door on the back drivers side. That gives me a good bottom vent. Then I open a couple windows and the top vent. If the temp is above freezing I don't get a ton of condensation. If it gets below freezing I get a LOT of condensation. It really depends on the temp and the moisture level in the air. The electric heater has much less condensation.JaSAn said:Idahoron: when you were using the Buddy heater did you have any problem with condensation (or with the Wave)? When I use my Buddy heater for an hour things feel damp, use it for four hours and things are wet.
jim
Where do you have it in your camper? My only issue with catalytic heaters is my dog. I have a standard Poodle that is quite tall, I don't think I can put in on a counter and be far enough away from the roof, they recommend 3'.michgoblue said:I added a Olympian Wave 3 heater to my camper and really like it a lot better than the Atwood forced air heater we have installed. Quiet, even heat, and no current draw.
