FWC EAGLE - dimensions of roof lift pan
joseph.hinker
Dec 7, 2019
24
Hello WTW,
Im rebuilding a FWC Eagle that was once a Grandby. I was wondering if anyone had the dimensions of the roof lift panels. I have the old Grandby ones but they are too big. What I need is:
- Length, width and thickness of the bigger piece
- Length and width of the smaller piece.
- distance from side of camper to where the panel starts.
I have been trying to do research on the panels and I saw that there is a newer wood panel and an older wood panel. The composite panels are really nice, I e-mailed FWC about the them and the price was way out of my budget.
Also pictures are great, so post them if you have them. :)
I have an Eagle with composite panels. It's the Extra headroom top. If you like the taller panel measurements let me know. I forget how much taller it is then stock but it was only offered 1 or 2 years before they canceled the Eagle model.
2000 Eagle shell: Overall width: 68", inside width: 65 1/2"
Bottom lift panel is 1/8" masonite, 58" x 22". hinge pin is at 13 1/2"
Top lift panel is 58" x 12 1/4".
Top of sidewall to roof is 25".
Send me an email and I'll send you pix. mark@markgentry.com
More headroom would be awesome. Do you think you could get me the dimensions?
So again sorry for the delay.
The canvas up is about 30" high.
Inside headroom is about 76"+.
The panel setup is the same front and back.
29 1/4" tall open with the hinges exposed top and bottom.
The top half panel is 47 3/4 wide and 14 1/2" tall.
The bottom half panel is 47 3/4" wide along the bottom and 24" wide at the top.
The line of rivets along the bottom panel measures from the bottom 1/2" and 14" also where the taper down starts to th 24" with at top.
I attached photos in case you want me to measure anything else.
