B100 or SVO / WVO
Chnlisle,
Based on your earlier posts when you are saying 100% bio I think you are talking about B100 Biodiesel not SVO (straight Vegetable oil) or WVO (waste vegetable oil). If you are talking about B100 Biodiesel which means it is 100% clean vegetable based fuel you will be fine. Here's a description of what it is from another web site:
"Biodiesel is a renewable, cleaner burning diesel fuel made from vegetable oil or animal tallow.
Technically speaking, biodiesel is called methyl ester or ethyl esters. Take vegetable oil and strip out the glycerin molecule and replace it with three alcohol molecules. Simply put, Biodiesel is vegetable oil modified with a lower viscosity to fool your diesel injection system to think it's still pumping petrol diesel. Biodiesel can also be produced from animal tallow.
B100 is 100% pure neat biodiesel. No diesel."
The important word in the above paragraph is viscosity. The problem with running SVO or WVO is that they are more viscous than modern diesel fuels and they gum up your injectors without pre-heating them to cut down the viscosity. The combustion products of them can also coke up your cylinders. B100 doesn't have those problems because they have stripped out the glycerin to make it less viscous and burn cleaner so your vehicle can't tell a difference at all.
The diesel was originally designed to run on peanut oil and likely would have remained a bio fuel engine from it's inception if not for an unfortunate accident. The original desiger of the engine was on a boat between France and england and never made it. No one knows for sure what happened to him, there have been speculations of foul play because he was going to sell the diesel engine to a foreign millitary. The upshot is that his research assistants took up the project and buckled to government pressure to use a petrol based fuel so they ran the engine on that. Early diesels can run on vegetable oil with no problem because the injectors were designed for it. It is only modern diesels that have the viscosity problem because they have been designed to the viscosity of modern diesel. This is one of the reasons that old mercedes convert so well to veg, their injectors were not yet designed to accept only modern diesel.
The short version is you can run B100 in any diesel with no conversion and no problems. I hope this helps.
Rich
