GPS Rollover Event April 6, 2019
ski3pin
Belay On
Site Team
RV LIFE Pro
Jun 30, 2009
15,650
Sierra Nevada Range
I received this notice making its rounds through the land management agencies. FYI
[SIZE=18pt]ATTENTION!!![/SIZE]
[SIZE=14pt]Prepare for GPS Rollover Week Effective April 6th, 2019 23:59 Z[/SIZE]
[SIZE=14pt]The Week Number on your GPS Device will reset to ZERO.[/SIZE]
[SIZE=14pt]The last time this occurred was 1999.[/SIZE]
A GPS week rollover will occur at the end of the GPS day on April 6, 2019, at which time the GPS week will transition from week 2047 to 2048. However, because the GPS message structure broadcasted by the satellites defines the week as at a 10-bit value, the GPS messages will indicate that the week has changed from 1023 to week 0.
[SIZE=14pt]Some of our newer devices should handle the rollover automatically – IF YOU KEEP YOUR UPDATES ON THOSE DEVICES CURRENT.[/SIZE]
[SIZE=14pt](devices that conform to IS-GPS-200 and provide UTC should be fine)[/SIZE]
[SIZE=14pt]Some of our older devices (trimble/garmin) may experience some issues. The one point to remember is to KEEP THE FIRMWARE OF THE DEVICE UP TO DATE.[/SIZE]
[SIZE=14pt]If you have Trimble Devices[/SIZE]
The table below shows the Trimble Mapping & GIS portfolio receivers and handhelds (released 2005 and beyond) that will continue to operate normally following the WNRO event, providing that the receiver firmware version is up to date.
[SIZE=11pt]GPS and GNSS Enabled Device [/SIZE]
[SIZE=11pt]Version [/SIZE]
[SIZE=11pt]GeoExplorer® 2008 & 3000 series [/SIZE]
[SIZE=11pt]GNSS firmware v2.11 or later [/SIZE]
[SIZE=11pt]GeoExplorer 6000 series [/SIZE]
[SIZE=11pt]GNSS firmware v3.06.1 or later [/SIZE]
[SIZE=11pt]Geo 5T handheld [/SIZE]
[SIZE=11pt]GNSS firmware v1.05.1 or later [/SIZE]
[SIZE=11pt]Geo 7X handheld [/SIZE]
[SIZE=11pt]GNSS firmware 4.50.3 or later [/SIZE]
[SIZE=11pt]GPS Pathfinder® Pro 6T/6H receiver [/SIZE]
[SIZE=11pt]GNSS firmware v1.03 or later [/SIZE]
[SIZE=11pt]GPS Pathfinder ProXT/XH receivers [/SIZE]
[SIZE=11pt]GNSS firmware v2.07 or later [/SIZE]
[SIZE=11pt]GPS Pathfinder ProXRT receiver [/SIZE]
[SIZE=11pt]GNSS firmware v4.44 or later [/SIZE]
[SIZE=11pt]Juno® S series [/SIZE]
[SIZE=11pt]OS firmware v5.0.2 or later [/SIZE]
[SIZE=11pt]Juno 3 series [/SIZE]
[SIZE=11pt]OS firmware v1.03.1 or later [/SIZE]
[SIZE=11pt]Juno 5 series [/SIZE]
[SIZE=11pt]OS firmware v1.0.8 or later [/SIZE]
[SIZE=11pt]Nomad® 900 series [/SIZE]
[SIZE=11pt]OS 1.2.2.0 [/SIZE]
[SIZE=11pt]Nomad 1050 series [/SIZE]
[SIZE=11pt]OS 2.0 [/SIZE]
[SIZE=11pt]Nomad 5 handheld [/SIZE]
[SIZE=11pt]All shipping firmware [/SIZE]
[SIZE=11pt]Yuma® rugged tablet computer [/SIZE]
[SIZE=11pt]Yuma 2 rugged tablet computer [/SIZE]
[SIZE=11pt]R2 GNSS receiver [/SIZE]
[SIZE=11pt]GNSS firmware v5.40 or later [/SIZE]
[SIZE=11pt]R1 GNSS receiver with recent firmware [/SIZE]
[SIZE=11pt]GNSS firmware 5.09 or later [/SIZE]
[SIZE=11pt]T10 tablet [/SIZE]
[SIZE=11pt]EM100 Empower module [/SIZE]
[SIZE=11pt]GNSS firmware 5.32 or later [/SIZE]
[SIZE=11pt]TDC100 series [/SIZE]
[SIZE=11pt]Trimble Catalyst™ [/SIZE]
[SIZE=11pt]Supported [/SIZE]
[SIZE=14pt]If you have Garmin Devices[/SIZE]
[SIZE=12pt]For many years, Garmin has anticipated and prepared for this event. Regardless, Garmin has been performing exhaustive testing of current and legacy devices to determine if they will be affected by the GPS week number rollover. Our testing shows the vast majority of Garmin GPS devices will handle the WNRO without issues.[/SIZE]
[SIZE=14pt]What is the Effect of a GPS Week Number Rollover Issue?[/SIZE]
[SIZE=12pt]For GPS devices that are affected, after the rollover occurs, an incorrect date and time will be displayed. This incorrect time will also be used to timestamp track logs, compute sunrise and sunset, and other functions that rely upon the correct date and time.[/SIZE]
Interesting...kinda like the old "Y2K" issue -- except it's Week2K.
Thanks for the heads up.
I wonder how my 2003 etrax is handling the time change, I’ll have to fire it up and check it out.
Thanks Ski3pin for the heads up.
