Hallmark Solar Wiring
Bfulls
Aug 12, 2017
5
Oregon
I'm looking to install a solar system on my Hallmark Guanella.
Can anyone share pictures or explain the wiring for the battery monitor? From Hallmark pictures they have the battery monitor mounted in the overhead cabinet above the sink. How do you get the wires from the battery into the cabinet? Any other mounting/wire routing tips would be appreciated.
Thanks
I tried to upload photos, but failed miserably. The monitor and controller are mounted on the aft end of the driver's side upper cabinet. There is a false wall inside the cabinet that covers the wiring from those units. The cables run through the wall side of the cabinet to the upper torque tube then back to the scissor tubes and down along those tubes and are routed as required from there behind the standing cabinet containing the fridge. Hope that helps.
Thanks that helps. I'm mainly interested in how the cables are routed around/with the soft wall. Are they "exposed" like the red wires in the drivers side aft of the camper? (Like the wires that I assume power the ceiling lights and fan.) If you are able to upload any pictures, I'd be most interested in the wire routing outside of the upper cabinet (wires along tubes and into fridge cabinet and/or ceiling). thanks again.
