Bombsight said:Does anyone , for certain, know what is behind the white molding strips highlighted between the green lines in attached photo?
I'm wanting to mount something to them and was wondering what is behind them ... if anything.
Thanks
Thanks, Poky! That helps a lot. Still a bit reluctant to drill into that area being as its 25 years production difference.PokyBro said:Bombsight,
Here's some shots of what you'd see under the white strips, and under the ceiling material, from my build. Yours should be pretty similar, even though mine was built in 1981, and yours is 2016,
ImageUploadedByWander The West1472008900.127427.jpgImageUploadedByWander The West1472008993.853896.jpg
Poky
Never thought of condensation.longhorn1 said:Bombsight, I was thinking of fastening into the aluminum roof frame for some fasteners to hang a strap off of. I was discouraged by FWC. The frame thickness as noted by FWC is 1/2". There is another issue you could run into. Condensation dripping from the fasteners. I think you could open a can of worms by penetrating the framing. jd
