Camper Eye Bolt Locations for New Four Wheel Campers
(these are a general rule of thumb that we go by, but sometimes there are slight variables for certain trucks on the market)
These all should be correct measurements for new FWC's, but we cannot guarantee the accuracy with 100%, as there are some strange trucks out there we run into from time to time and we need to make adjustments on the fly.
IMPORTANT NOTE: Older four wheel campers WILL have DIFFERENT eye bolt measurements than what is posted here. The measurements above are pretty accurate for any new FWC manufactured in the past year or two.
Grandby Model:
Original Roll Over Couch Floor Plan = (front eye bolts 12” back from the front of the truck bed / rear eye bolts 76” back from the front of the truck bed).
Side Dinette Seating Floor Plan = (front eye bolts 12” back from the front of the truck bed / rear eye bolts 76” back from the front of the truck bed).
New Front Dinette Seating Floor Plan = (front eye bolts 11” back from the front of the truck bed / rear eye bolts 74” back from the front of the truck bed).
Hawk Model:
Original Roll Over Couch Floor Plan = (front eye bolts 12” back from the front of the truck bed / rear eye bolts 61” back from the front of the truck bed).
Side Dinette Seating Floor Plan = (front eye bolts 12” back from the front of the truck bed / rear eye bolts 61” back from the front of the truck bed).
The newer Front Dinette Seating Floor Plan = (front eye bolts 11” back from the front of the truck bed / rear eye bolts 58” back from the front of the truck bed).
Raven Model:
Roll Over Couch Floor Plan = (front eye bolts 12” back from the front of the truck bed / rear eye bolts 51” back from the front of the truck bed).
Fleet Model:
The newer Front Dinette Seating Floor Plan = (front eye bolts 10” back from the front of the truck bed / rear eye bolts 57” back from the front of the truck bed).
Eagle Model:
Swift / Finch Models:
Original Roll Over Couch Floor Plan = Most ALL Finch Model camper installations require the camper to either be “bolted down” to the truck bed, or you can sometimes use the “External Camper Tie” downs if Tork-Lift makes a kit for their truck ?
The only exception to this usually … If the customer has a 2005 – 2016 Toyota Tacoma Standard Cab, Access cab, or the CrewCab with the LONG 6.0’ truck bed. If the customer is putting the Finch Model on the 2005 – 2014 Toyota Tacoma truck that has the LONGER 6.0’ bed, they can use the custom made FWC black steel Tacoma Bed Bars we sell for tying the camper down on the truck. Please call your factory rep. or the FWC service department for more information & details on this. These installations are not that hard, but they are different.
If in doubt, PLEASE CALL our service department (800) 242-1442.
We can help clarify any questions or concerns you might have.
Thank you.
_________________________________________________________________________________________________________
fireball said:
Hello all,
Surely this is posted somewhere so maybe someone can be kind enough to point me in the right direction.
I have a 2008 Tundra and will be picking up a 2014 Hawk in a few weeks. I'm trying to find out what I will need to do with wiring and attachment points for the camper.
Thanks!
