HELP -- Dometic RM2193 vs. RM2193L -- is there a difference?
Big Steve
Apr 18, 2007
32
I need to change out the fridge in my 2000 Hawk. I have found a great deal on a Dometic RM2193. But, I also saw reference on this forum to the Dometic RM2193L. Is there a difference between these two model numbers? Any help would be appreciated. Thanks.
Hey BigSteve
I took a look at the old manual we have on-line and it lists that model as the RM2193.
Then I did a quick web search to check for "Dometic RM2193L" and the only results came up were a posting from Ben on the WanderTheWest website.
Here is a copy of that post from back in 2007 ...
I'm guessing that it should be the same model, but I can't tell you for sure ?
You might want to call Dometic customer service and see if they can tell you the difference.
Dometic Customer Service # is 1-800-544-4881
My WAG is that the "L" model has a left hand door as shipped instead of a "normal" right hand door. The parts list for the RM2193 has both LH and RH hinges available.
Good call !
I think NJ Taco is right
That would probably be the reason for the "L"
Thanks for the input guys. The RM2913L checks out as the right unit. I was lucky to find it on Craigslist for $300, brand spanking new. Hope is isn't too much of a PITA to install.
Steve,
Sounds like you scored on the fridge. I've had my fridge out twice, once to install the heater and once to rebuild/reinsulate the fridge compartment and the whole process is fairly easy. If you have any questions I'm sure they will be answered by the members here. Good luck.
