help w/2 interior bobcat dimensions
JzeroThree
Dec 29, 2020
9
I'm hoping for some assistance with two measurements inside the bobcat...
From the edge of the door to the end of the floorspace on the passenger side.
Then from that corner up until the wheel well box corner. (Looks about 20", but I'd like to know for sure)
Just trying to find how much space the little bit of extra room at the back of the camper on either side of the door there is. Also, the door is 24" right?
I appreciate any help!
The red lines are the two measurement distances I'm trying to find. Hopefully the picture helps clear up my description.
On my Bobcat I have a side dinette so it doesn't look like your picture.
But the area where you need the measurements I use for the portapottie
from the door to the corner it's about 10" from the wall to the "hold down box" is about 18".
Hope this helps.
Ten inches and twenty-two inches, but I would not count on these to be "factory specs" as our Bobcat floorpack was built to fit our truck. Think of it as ballpark.
