Tail Gate Construction
At the request of 2llamas here are a few more shots of the tail gate and answers to llamas questions about the construction and attachment. Remember this was built as a prototype out of mostly material I had on hand and a few misc. bolts from the hardware store.
Questions:
1. Is the deck attached to the receiver? - No, though it could work very well with some additional support. The deck support is a piece of 2 x 8 DF bolted thru the bumper in three places. The lumber started splitting after about 8 months and I add 3 - 1/4" x 3" x 7" steel plates to reinforce it.
2. How is the stringer (deck support) attached to the deck? - With 4 - 3" free pin door hinges allowing a full 180 degree swing.
3. Do the cables on the side hold it steady against wobble? - Since the mounting is bolts and hinges the type of wobble you get from a receiver attachment doesn't happen. The cables, which are just pieces of chain covered with garden hose, only hold it in the horizontal position.
4. What do the cables attach to inside the bed? - The chains are bolted to the original tail gate cable attachment points.
I still hope to have a refined version of this built some time in the future, but who knows when or if that will happen.
2llamas, thanks for your interest. Hope this answers your questions, if not I'll be glad to provide more info.
