Continued from above...
Bases installed.
Pro Tip. I use these to keep open tubes of sealant fresh, they are little condoms for your sealant. Been using these for years and they work great!
Starting to run wire. I always use pre-tinned marine wire when possible as it offers superior corrosion resistance. Each individual strand of wire is tinned before being wound into the complete wire.
Wire ran through the compression fittings and ready to install.
Finishing the install.
More 221 to seal the screws on the top case. The rubber fitting is tapered and as you tighten the upper housing it squeezes the rubber around the wires creating a water proof seal.
And all in place.
Temporarily sealed off the ends of the wires and snap tied them to the rack.
Lots of wiring....
I'll clean this wiring up soon.
Quick diagram for the wiring. There will be a junction box up top to handle the power distribution.
More to come....
Hodakaguy
Bases installed.
And all in place.
Lots of wiring....
More to come....
Hodakaguy
