How to you secure your FWC?
Kolockum said:
Look up tuffy lock boxes. Solid product. They did not make a model specifically for my dakota so I measured and found one that could fit with little modification.
My motto is out of sight out of mind.
I've set up a Pelican 1510 case which rides behind the drivers seat, where I've removed the rear seats of our access cab. I lock the case to a Kryptonite cable that I've threaded through the metal body of the Tundra storage compartments. It won't stop someone with time, but smash & grab attempts should have a tough time. I keep it covered, and my rear windows are tinted dark.
"Out of sight, out of mine" Is best insurance.
Another thought: Don't flash your gear around, then walk away from your truck. I tend to keep most gear hidden from view as a general practice.
Pro tip: you can slip a laptop between the mattress and the dropped top. With a neoprene sleeve, we even travel rough road with a lapper tucked up there.
I made the inside deadbolt knob removable so the bad guy can't unlock it if he breaks the window. If I'm inside the camper I can put it on and lock the door.
