I upgraded my camper wiring /doh
craig333
Riley's Human
Jan 12, 2007
8,158
Sacramento
I've been meaning to either upgrade to a single larger gauge wire from the truck to the camper or just parallel another wire on back. Since I had smaller gauge wire I went with that. Rather than run it alongside the original wiring I decided to run it on the passenger side and since the truck has dual batteries that'd be pretty easy. So I did. I ran a hot and a ground both fused on each end. Overkill but I'll never have to worry about a short. Ran all the chafe points through a length of hose. I was happy, all was well and good.
As I was cleaning up and putting away all my tools it suddenly dawned on me. I hadn't put in a disconnect at the camper /doh. I'll just have to do that later the next time I take off the camper. Assuming of course years from now I don't completely forget! I'll also have to remember if I ever need to isolate the truck or the camper for some reason.
Btw, it still runs through the switch if don't want it connected to the truck.
Just a warning about running parallel circuits. Not really a good idea especially if as you did the wire lengths are not the same.
It will work but not the optimum solution.
Dsrtrat
I have to admit much of that went right over my head. I took all my electronic equipment out to the camper, everything seems quite happy so I don't think that applies in my situation. My hot wire is only a couple feet shorter than the original, I doubt thats significant either.
Mine too if you're talking about the link. Posted it in case you were interested in knowing more about the phenomenon. Oh gawd, "phenomenon"....
sorry about that......
