Hi All,
Just picked up a Grandy and beyond excited to get it ready for some adventures. Curious if there is an optimal cab clearance for these? It will be going on a Ford F350. I've measured that if I install the grandby, I have only 5/8" of clearance with my horse mat installed. I presume that you want it as low as possible, with just a little bit of room to account for flex? So my plan is to buy a 4x8" sheet of rigid foam from Home depot. I am either going with the 1.5" or the 2". I know this is approaching neurosis with such a negligible difference between the two, but which would you go for? Which ever foam I choose, I still add that 5/8" of pre-clearance. TIA for any input.
