Input on Possible Solar Setup for FWC Raven
Thanks Vic.
The only concern that could think of for the large residential panels is possible higher susceptibility to damage from vibration on a camper that experiences a lot of rough roads due to the larger span between the supporting frame around the panel.
However, I can conceive of adding some damping material to the mounting (somehow) to damp out some of the vibration of off road driving. I don't actually know if this is a legitimate concern or not. I have never read of a solar panel fracturing as a result of a vehicle driving on rough roads.
These larger panels are worth considering for new install. I think for many campers 160 W is a tad on the not quite enough side if staying in one place for days and if there is any cloudy weather of partial shade during the day or a combination of fan or other 12v use is high (due to hot weather - vent fan or cold weather - heater fan, etc).
For similar weight and not much more money a 200 watt to 360 watt panel will provide margin against successive days of cloud cover or higher fan use, etc.
I am still crunching the comparison numbers. ;-)
If one cannot source locally, what is the cost of shipping a large panel? When I bought mine, large panels were cost prohibitive because of shipping cost.
Are large panels susceptible to shading the same as smaller panels? Or are they connected so partial shade does not affect the whole panel.
In this thread I didn't see mention of lift type - electric or manual. Anyone considering the heavier glass/aluminum panels might want to test the extra weight first if you have a manual lift. I have 3 thin flexible panels, two high quality and one average, for total extra weight of about 12 lbs. and 300W. My gas-strut-assisted lift is still good but I wouldn't put any more weight than that on the roof.
ckent323 said:
Thanks Vic.
The household panels I have used are rated to withstand crazy sized hail and snow loads. I can personally vouch that driving 100 miles of terrible washboard at speeds high enough to create a dumped out fridge and multiple screws vibrating out of the framing did not damage the solar panel.
Agreed. I have 80# struts on mine to aid in lifting the panel, canoe and sand tracks on the roof.
