Bingo. Those wires on the volt meter are wicked short... so 2 'Y pigtails' were necessary to make it easier to connect.
All in all I am happy. Being a furniture maker by trade a suggestion: measure the opening from the volt meter, cut a piece of thin wood to that size, put a piece of 2 sided tape on it, place the piece where you want the volt meter, use an exacto knife to score around the piece of wood (this keeps plywood with veneer from splintering when cut...clean edge) drill small holes in each corner, use a forester bit and drill as many holes inside the score lines to remove most of the wood, use a small blade hand saw to cut out the remaining wood 1/16" or so from the score line, then use a rasp to smooth the final opening...I did add a couple notches on the side for the clips that hold in the meter also with the rasp. Nothing in life is perfect... so I am happy.
