jkidd
Started working on some LED camp lights to use around camp when setting up camp. Here's what I came up with. A plate to bolt to the jack bracket with a 1 inch ram ball. A plate to mount 2 18 watt LED lights. It can be removed and store when not needed. They can be mounted on a tripod and moved anywhere in the camp. They can be connect to the house battery or use a Goal zero Yeti 400 for portability. They use 36 watts or 2.3 amps and I can disconnect 1 of them to reduce the power consumption to half. They put out 1200 lumens for each light.
