Mark,
The MPPT controllers pull out way more power from the panels than a PWM controller can. And to do that, you need to wire the panels in series, to pump the voltage up and give the controller room to play in.
The advertizing/review on the 100/50 is flashy... and the same applies to all the Victron controllers. They are all very quick. So don't let that disuade you from getting any other Victron controller!
The series/parallel connection thing is even more important for those remote/portable panels, because instead of a 10' of wire, you now have 5 to 10x that. I have 100' of cable for mine, so I can get them into the sun easily if I am in the shade. That's why I have TWO Victron controllers. One for the roof array and another for my portables.
LiFePo4 batteries discharge about 3-4x slower than regular chemistry batteries. If you are not parking for months, it won't be an issue. Otherwise, I second Craig's recommendation of a NOCO Genius 7200. I use one too.
I have bluetooth on my battery monitor, and at the time I didn't include bluetooth for my controllers. I don't miss that feature much, as I ALSO have the remote displays and can change settings from those. That said, there is little need to adjust the controllers. I love having BT for my batteries, as I can monitor them from the house or cab of the truck.
Sorry about the upside down gauges!
