Looking for a used slide-in camper for a 2017 long bed Tacoma
rau
May 11, 2017
2
Hello everyone,
We're actively looking for a used slide-in camper for our new 2017 long bed, double cab Tacoma 4x4.
Here's the truck bed measurement:
42" width between wheels
7'8" length with tail gate down
42" cabover height
Ideal weight of the camper: 1000 lbs or less
Also, considering that it's a small truck, we're asking for suggestions for brands and models that we should be looking for. As far as we know the following camper would be ideal:
Four Wheel Camper: Eagle, Swift and Fleet
Palomino Bronco 600
Viking (not sure the model)
Other than that, we don't really know what else to look for. Very few people list their item with enough description and most of them doesn't know that much when asked. We see the following brands but we don't know if they are ideal for our truck:
Skamper 100s
Jayco
Sun Lite
Starcraft
Coachmen
Tracker
Apache
We're also watching this thread:
http://www.wanderthewest.com/forum/topic/7380-used-pop-up-truck-camper-alert-thread/page-270
Suggestions are much appreciated. Thank you very much in advance.
I had a Bronco 600 in a Nissan Frontier long bed, it was pretty heavy (1000# empty), and the cabover was low, I had to raise the camper about 4 inches to clear the cab which gave me a high COG. I sold it last month and just got a FWC Fleet. The fleet is so much lighter as I bought a shell, but I can see that a lot of the FWC weight is much lower, the B600 has a heavy roof with a heavy lifting system. I know they are more expensive and hard to find, but in my opinion the FWC is a much better made camper. I haven't seen an ATC but from what I read and see on the forums, they seem to be similar to the FWC.
It goes without saying that you will need to beef up your suspension to handle the weight, not a bad idea to add E rated tires too. My rear axle is coming in at around 3000# unloaded, the front is unchanged, loaded or empty.
If you do decide on a FWC or ATC, the used ones go incredibly fast!!! So get yourself ready.
Good luck, if you haven't had one before, they open up a whole new world of exploring.
Josh
Wandering Sagebrush said:
Look for an ATC Bobcat shell. Its light, 7 feet long, under 1000# and as many will testify... "Built to Survive".
https://www.allterraincampers.com/Bobcat
Thank you! Will look into that!
Josh
Thank you for sharing these info. You think just adding Timbrens would be ok as far as the suspension goes?
I added Timbrens to my Ranger, which already had a tow package and beefier suspension, and that was not enough for a 1000LB camper - basically the rear end rode on the stops of the Timbrens all the time. I ended up getting airbags and its a lot better ride with or without my camper (was a Four Seasons Magnum now a Phoenix).
I wouldn't spend the money on Timbrens if I were you - lots of people have Tacomas and have posted their suspension upgrades - I would heed that advice instead.
I had Timbrens for a while, they really did not cut it after a few days with all that weight, they just gets compressed. I put air bags on and they make a huge difference, and you can adjust the load easily.
Look for an ATC Bobcat shell. It's light, 7 feet long, under 1000# and as many will testify... "Built to Survive".
<snip>
Let me expand a little on ATC... When you call the company, you're talking to either Jeff or Marty, they're the owners. When you want something custom, the answer is almost always "We can do that.". In the rare case you have an issue, there is a clear customer focus on getting it quickly fixed. If you want after delivery modifications, not a problem. Need a repair on a different brand camper, chances are they can do it.
I'm impressed with these folks.
If you are still in the market I would give Rory a call at Bundutec. They have a few different options as well as building something totally custom. You will be (pleasantly) surprised with their pricing. I got a totally custom camper for my 2013 Tacoma for less money than a lot of used good condition campers. Mine weighs in at 950lbs wet.
I am also using a set of SuperSprings. Easy installation and they work really well but they do "squeak" a little bit.
