HERR42
01110010110101
you guys know that i have been whining about that stupid bolt used to hold down the lp bottle...well i have an idea.
get a bolt - grind the head down so that it is a stud.
drill a hole crosswise just big enough for a pin.
screw it into the nut, loctite it.
if the hole is high enough to allow the bottle's bracket to slip over, then a washer, followed by a pin.
voila! a quick and easy hold down clamp....no more wrenching!
will it work?
can you decipher what i am explaining?
will it work?
