DrJ
I installed a trimetric 2030 in my Hawk earlier this summer. It is a highly useful piece of equipment for monitoring your battery useage. It provides real time data about your camper's power. I've had several other monitors and even a volt meter, but until I installed this I really didn't know for sure about my battery's actual status.
I've taken several measurements over the summer and here is what I found. I'm hopefully that this is helpful to someone else.
110 liter Compressor fridge 4.2-4.8 amps per hour
(That's the big one that FWC uses)
Heater 2.5-3 amps per hour
Water pump 2.6-3.2 amps per hour
(depending on volume of water)
Old incandescent overhead lights 2.8 amps per side or 5.6 amps for both sides
New LED overhead lights 0.4 amps per side or 0.8 amps for both sides
LED floor lights 0.1 amps
LED flood lights 2.8 amps
Porch light 0.2 amps
(Replaced with LED)
Fantastic Fan
0.2 amps at 10% fan speed
0.5 amps at 50% fan speed
1.5 amps at 100% fan speed
FWC battery sensor, IOTA IQ4 smart charger less than 0.1 amps - not measureable.
A couple of take home points for me.
LED light replacement is the best and cheapest way to decrease battery useage. The new ones use 1/7 of the power of the old ones.
Furnance uses less amp hours than I suspected.
I would have guessed 5-6 amps per hour.
(Replaced with LED)
Fantastic Fan
