munchmeister
I've got a FWC Raven shell which had the Thule racks when I bought it. I'd like to mount a 100 watt or so panel and use the pre-wired SAE plug to charge a battery or two that I intend to mount into the interior side benches (its a shell, so there is no battery compartment, no cabinetry other than the narrow hinged lid.)
Can any of you steer me to what I'd need to install a panel close to roof (i.e. not using the rails and rack system) by just utilizing the Thule tracks that are the basis of the Thule system?
I'm thinking I'll get a couple of narrow batteries which can fit into the narrow space that is available under the hinged lid. The rear end of this space has the wiring stubbed in and labeled, Guess all I need is to hook up batteries to the correct feed from the roof top panel. I'd probably only be running a Fantastic Fan (also yet to be installed) to keep the interior of the shell cool when its hot and to run the LED lighting rather than pull power from the truck battery.
Thanks in advance.
Thanks in advance.
