So I have just bought a 1969 Alaskan 8' non cab over.
When I went to look at it, it had the ratchet or screw type jacks (2). They are sketchy at best and i have zero faith in them.
I was looking at the Rieco standard tripod jacks (4) and I have a question.
Do I need to mount these or can I for the purpose of getting this on my rig, just lift as is? What is the risk?
I will not have time when I pick it up to mount them right and use a backing plated. I can do that once I get it home, if I need to. I would prefer not to at this stage as I need to go through the whole thing.
Once I verify the wood is good I plan to install the jacks properly but for now I just need to get it home.
The goal of this is to restore it. Looking at it someone (not the PO) did a hack job on the wiring as a
whole, the Fridge is wired all wrong and the furnace has been pulled.
Anyone know where to find a furnace?
Inside looks good with no visible signs of leaks. Exterior....well some dents. Someone put an externally mounted fuel can holder and propane tank holder. Both will come off.
As well the jacks need rebuilding, I am 100% sure there is wood rot somewhere so the siding will come off and the rusted screws will be turfed and new stainless will go on.
Etc etc.
This is a winter project for both my kids and myself.
To get it home it will go onto my modified M101A2 trailer. This will work fine but not its final home. I plan to pickup a 3/4 ton or 1 ton truck next year.
Etc etc.
