New batwing awning
Here is the image of the brackets
buckland said:
Was wondering if someone wouldn't mind sketching the stainless brackets with measurements. I called FWC and was quite impolitely told they aren't for sale. I'd like to attempt to do the same mount as Hodakaguy did for the Alu-Cab. All that is needed is to have the rear most mount bracket welded to a vertical piece that bolts to the jack stand bracket holes on the corner. This makes the hinged end of the awning rock solid (I've been told). Maybe AT campers would be more open to help?
That's real annoying and disheartening that FWC won't sell you the brackets. I have the the factory installed Eezi-Awn batwing awning on my FWC. I'd be happy to send you photos of the brackets and the hardware on the inside of the camper if you want to try to source them elsewhere.
