new panther
strom windows and racks
erod,in regards to your question on air pressure i should of said i air my tire pressure down to 23 or 24 when the going gets rough air bags stay at 55lbs or close.what i did to hold my window covers in a shade position i used some lengths of pvc pipe drilled small holes in end then with nylon zip ties fastened 2" pieces of velcro at each end that way you can adjust into any position. ,works great and does not add weight! when i get back from our summer in idaho which will start in about 2 weeks or so i'll be changing back to 4wc set up and i'll take some close ups of my gas can carriers (up to 4 cans) ladder/rack for 5 gal water can/satelite dish,outside flip down shelf{great to keep bugs off food prep when camping,roof mounted solar panel,3 bar roof rack,also a special roof rack that holds our double kayak and flips out so you can raise roof on camper with out unloading kayak,also rear mounted propane bottle.on the front of tacoma i have a frame mounted push bar that enables me to jack front up with high-lift jack,makes it some what easier after i get it stuck in the sand etc! remember "its the journey"
can't wait for the photos, sounds like a great set up, creative and functional! thanks again!
