New to FWC
I’ve hopefully attached the Deka agm battery stats. Not all are the same, this is what fwc has been supplying. I understand Trojan batteries are a bit more robust also.
  • 8A-8G I&O_2012.pdf
Ok copied and pasted your battery charging specs from your PDF.
My Fiamm AGM factory installed battery's in my 2015 Hawk from FWC are specked:
"Cyclic" 14.4 to 15.0 volts.
"Standby" 13.5 to 13.8 volts.
This is within the Iota puts out with the built in AGM module and have had zero problems.
Of course you have reported having disastrous results in your model year and factory installed battery's. I guess each system will be slightly different with different results.
