Hello all!
I am wanting to add a solar panel to the roof of my FWC. I have researched the information on this forum but haven't found a scenario exactly like mine.
Here is some info about my camper:
-I have an SAE connector on the roof
-It is all pre wired (see images)
-There are several wires in the fuse box area where I will connect the panel I imagine
-There are also a red and black wire in the battery compartment (see image)
-My camper is a 2015 Eagle.
My questions. What exactly do I need right now? Just a panel and a regulator? Where can I put the regulator? (I'd like to put it under the bench where the fuses are. What will I connect to what? Does anyone have a wiring diagram for this?
Thank you!
Thank you!
