ckent323
Karlton,
If you have a solar plug on the roof and you have wires for solar in the battery compartment then I think you have all your need.
If you have a voltmeter you could get a long small ga wire and connect it to the end of one of the terminals on the roof connector then connect it to your volt meter in the battery compartment and check for continuity with the solar wires. If you have a connection then you are done. All you need to do is install a Solar Charge controller between the solar wires and your battery. You may want to also add a battery monitor and shunt as well.
I had to locate the wires in the ceiling of my camper and install a Solar port in the roof. The other end of the wires were near the water pump under the forward end of my cabinets. I had to run those wires to my battery compartment and connect them to the Solar charge controller. The wires came down from the roof on the drivers side of the lift panel (just behind it) and into the cabinet.
If you do not get continuity between the roof solar port and the solar wires in your battery compartment then you care going to need to search for them.
If you need to search first call Terry Budd at FWC, they have a drawing of where the wires are in your camper (assuming it is newer than 2007). They will need the serial number of your camper to look the drawing up.
Does that help?
Regards,
Craig
Does that help?
Regards,
Craig
