WarpathEngineering
- Joined
- Oct 14, 2006
- Messages
- 101
Here in Kentucky the weather is finally starting to turn for the better so I've started back on renovating my '99 Grandby. When I bought the camper back in October from a guy in Virginia I noticed a lot of moisture damage up front at the bed board. Thanks to Marty and Ben for all the advice up to this point! I also noticed when I picked it up that the front and rear hindged roof supports are delaminating and sagging to the point that they are not holding the roof up to the full height. Today brings a continuation or should I say an escalation of the same. When I got into the camper this morning after sitting around waiting for the snow and fridgid tempratures to subside I noticed water stains on the floor pack where the cabinets used to be. Water droplets had formed around the sideliner windows. When I raised the roof up, water ran out of the window openings, water filled the holes in the screening in some places and a layer of water was once again on the bed board. The front and rear folding supports where wet to the touch both in front and behind. Next came the headliner which was also wet, not damp to the touch. Since the headliner was incredibly dirty from the lack of care given in its previous life, I removed it to find a fair amount of mold covering 50% of the back of the headliner and the insulation that was so wet, some spots were still frozen in ice like a spounge! What is going on??????? By all appearances the roof is in dented but good shape. The screws are rusty but tight and need replacing before they stain (If buying new, I would pay extra for stainless steel hardware! hint hint). The underneath of the roof shows no sign of water staining but water droplets were present in places. The center roof seem appears to be tight from below and caulked from above. The side liner, apart from a few pin holes at folding areas is well attached and tight. All the different layers of the sideliner windows are present and apart form lying a little crooked when sealed up, fit good. When the top is down, with or without the clamps, I see no signs of a gap which would leave me to believe that rain water is blowing in under the flashing. My roof does have the four vents but from the inside it looks as if someone, I assume at the factory, filled the holes from the inside with expanding foam. Could this be the answer? Do you think that all this damage was caused by condensation? It seems a massive amount of water to me. And this doesn't bode well for the future either. Here in Kentucky, summer humidity can easily reach 75+% for weeks on end. I know that this sounds like a narrative but there is a question there somewhere. What do I do? Has anyone had this problem? How do I fix it? I'm at a loss!
