First, you should make sure that the photos aren't much wider than 900 to 1000 pixels wide, and resize them if necessary.
There are basically three methods to insert photos in a post:
Method 1) First upload the photo from your computer to somewhere on the Internet (such Photobucket), then use this image icon
from the posting toolbar along with the "Image URL" that points to your uploaded photo and this will insert that image into your post.
Method 2) First upload the photo from your computer to the WTW Gallery (ideally the appropriate sub-gallery for your photo's location, such as, for example, Gallery>California>Warner Mountains: From the Warner Mts Gallery page, select "
New Image", then "Choose File" (from your computer), select a Spot, then Submit. From the photo page that results, Copy the "BBCode" below the image, e.g.,
[IMG
http://www.wanderthe...31_95_33304.jpg/IMG]
then Paste that code directly into your post.
Method 3) Click on the navy-blue "Click to Attach Files" button below the text-entering window (where you type your post), select the photo you want to upload (the image file must be less than 500kB (kilobytes)) from your computer, then after it shows up listed under Attachments, position your cursor in the text-entering window where you want the photo to appear in your post and click the "Add to Post" choice on the right. Using this "Attachments" method the total file size of photos per post is 500kB, e.g., you could Attach 3 photos if each image file was 150kB.
If this isn't clear or doesn't seem to work, ask more questions.
