Ruck_and_Roll
Hi, hoping for a little feedback from those other Victron users here.
Recently finished install of my solar system, Renogy 160 watt panel, Victron 75/15 controller, and the Victron MPPT Control monitor/plate. Based on the bluetooth technology and my already installed BMV-712 seems everything is working and I'm getting charging.
My only problem is the supplied power cord is not long enough to reach my battery box so I can't program it and would have to rely on presets through the iPhone application.
My limited understanding is that that I can power the control through either the VE.direct cable that connects to the charge controller or the supplied power cable. The supplied power cable is fused and isn't long enough to reach my battery.
So two questions:
1. Any further benefits with the VE.Direct Cable? The manual is pretty spartan. Any other benefits with connecting through this cable (besides power)?
2. Did anyone else have this cable length issue with the supplied cable that goes to the battery? Can I just splice and lengthen the wire?
So two questions:
