there are usually 2 or 3 common problems for that ...
1. The small small slits at the end of the propane tube (where the flame is actually burning) are clogged up. I have seen rust on some, and others were clogged with a small spider web that resrticted the propane flow just enough to where it would not stay lit. Easy fix once you get the part out. Check it, clean it, maybe a quick blast with compressed air. Re-assemble and give it a try. I have seen some that came out in 3 or 4 minutes with a screw driver, and others took up to 1 hour to get all of the parts out of there.
2. The thermocoupler is out of alignment. The thermocoupler is the small rod that is directly over the propane flame. If the thermocoupler is not directly over the flame, it won't get hot enough to tell the refrigerator to keep pumping propane and the pilot light will go out. I have seen some of these that worked loose and shifted out of alignment (easy fix, just re-tighten). Others just needed to be bent a little so they were over the flame (as much as possible).
3. Make sure you have enough propane and your tank is not too low.
Those are the easy to look for things that I can think of off hand.
hope this helps ...
Howdy,
Ever since I bought my Eagle, I have had problems running the fridge on the propane (works just fine on battery and shore power). I can get it to light but it won't stay lit. The pilot will light and the fridge stays fired up for about ten minutes or so then goes out. Most of the time I will not get it to re-light and if I do, it won't stay lit.
Any ideas on what the problem could be?
Thanks,
