My propane leak issue, which I had chronicled in a separate thread, finally pointed to a bad leak detector. I did have a very small regulator leak, which I solved by replacing the regulator, but the root of my false alarm problems turns out to be a faulty alarm. I’ll not go into all the troubleshooting I did on the alarm, but believe me, it has gone bad. My camper is a 2008 Hawk, manufactured in May 2008. The leak detector is a CCI Controls, Model 7770.2, manufactured in April 2008. I finally got around to calling CCI today to see if they could do anything for me. All of the numbers I could find for them were out of service. I did a Google search and found an interesting article posted at http://www.forestriverforums.com/forums/showthread.php?t=4722 . It turns out that CCI has gone out of business and that there was a rash of bad 7770.2 controllers that they produced from 2005 – 2008, which fail with the same symptoms as mine. Looks like I’m out of luck in dealing with CCI.
Stan, can you help me out? (And, I presume there are other Four Wheel camper owners who are or will be in my same predicament.) Are you guys now using a different controller that has the same form factor? What advice can you give me?
Thanks,
Norm
Thanks,
Norm
