Quick Release Shower valves
jbgoflyakite
Dec 31, 2015
20
S.Cal
I have a 2015 hawk. It came with the "old" Quick Release Shower valves. I lost my shower hose. I would like to replace it but apparently FWC changed the valve and no longer can get me a replacement hose. I looked online and all sorts of RV and hose companies. I cannot find a fitting that fits the quick release. What am I supposed to do without a shower hose? Anyone have a suggestion?
Thanks, I actually got the manufacture's contact info from the assembly. The manufacturer doesn't offer the hose anylonger... I guess that is why FWC changed the fitting all together but..... what is everyone supposed to do?
That quick release male adapter resembles a standard compressed air quick release adapter but it is not the same size. In my search, it seems to be a Phoenix shower unit or a Valterra shower unit.
https://www.amazon.com/Phoenix-9-SA-PT-ADPT-Quick-Connect-Adapter/dp/B003HK57T4/ref=pd_bxgy_263_2?_encoding=UTF8&psc=1&refRID=RPE5TDB8E74S0NYACVCG
Faucet may be a Dura unit. https://www.amazon.com/dp/B004NBDLYE/ref=sspa_dk_detail_0?th=1
I wonder if FWC bought the Dura hose assembly & replaced the adapter with Phoenix quick release male adapter?
At less than $15 for one of the Phoenix quick release adapters, it might be worth acquiring one for a test fit and if good, you could build your own hose with a shower head of your choice. Could then insert a shut off valve in line and use it with a shower enclosure of your choice.
Do a Google search for “Spray-away quick connect”. Lots out there.
I'm now in the same position and wonder if you ever found a solution for the outdated shower hose problem? Mine was stolen out of my Fleet propane compartment along with the two tanks over the winter and I need to replace it. Hope you're still around! Thanks
Not to get rich on this, but I have a shower hose from my 2013 Hawk that I no longer need. I recently converted my original outdoor shower to the current one being delivered. If anyone is interested, contact me and we can work it out.
Check Home Depot try some pressure washer disconnects fittings they carry an assortment of fittings buy the pressure washers.
Thanks, All! I rigged up a shower using the quick release fitting suggested by Four Wheel and a Camco RV shower head/hose. Had to buy some brass fittings to adapt the two. First time out it worked but leaked like crazy and who can waste that much water? I'm trying out different washers and contacted the member who has the old shower hose to see if it's the right one.
Stan@FourWheel said:
See links here . . .
Outside Shower = $ 45.00
https://www.dwincorp.com/product/hot-cold-spray-port/
Quick Connect Fitting = $ 7.00
https://www.dwincorp.com/product/quick-connect-valve/
Hose Barb (so customer can make a new shower hose & wand) - $ 5.75
https://www.dwincorp.com/product/hose-barb/
Does anyone know where I can find a new wand for the most recent outside shower fitting? I have 2019 Hawk. The reason is I would like the hose be at least 2-3 times longer to reach a shower tent. So I don’t have to put it so close to the rig.
Has anyone had to replace the o-ring in the QD fitting? Mine is looking a bit rough. I'm assuming I can pull it out and hit NAPA or any farm store with an o-ring assortment.
