nikonron
May want to have a look at the light output of that one light, I believe you'll find that it is more than enough lighting. Ron
Longbeard87 said:Thanks all. Only reason for pushing to get both is because I have a drift boat trailer so it is a little nicer having a beam of light down both sides when backing up on ramps, loading, etc..
Can you share those measurements with us?Longbeard87 said:FWC gave me measurements for drilling a hole that exposed the wires in each corner. Unfortunately it doesn't seem like they are a direct feed, no continuity to the main panel. I am guessing there is a spot for a switch to be added. Still trying to figure that out. They are always really busy in the service department when I call.
West Marine?fish more said:I updated my rear lamps with a pair of sail boat spreader LED lamps. Very bright with a wide beam, much better coverage !!
