fuzzymarindave
I found some water in the inside channel of the rear window in the 2015 Hawk. I've got a call into FWC to see what they might suggest. The caulking around the aluminum window frame looks to be completely sealed against the fiberglass siding. Only other possible source is water getting between the glass and the rubber seal as assembled from the window manufacturer. Even though the rubber looks pretty tight against the glass I'm tempted to insert some flexible butyl rubber sealant or other material that does not harden. Any direct experience with this problem or other ideas would be appreciated. thanks,
