Does anyone have a photo of the refrigerator fan for one of the compressor refers? I am thinking about adding one to my Grandby.
Originally the 110L fridge in my Grandby wasn't vented to the outside, only to the inside. As a result the compressor would run non-stop unless the thermostat was set just below 5. I told FWC about this and they put in top and bottom vents to the outside and insulated around the fridge so outside air couldn't enter this way. Had a warm fall here and it seemed to work much better. The real test will be this summer. I do not have a fan.Fitz said:Mine is not vented to the outside, To avoid dust and cold temps I did not want to cut a hole on the outside of the camper. In addition to the vent I cut next to the stove there is about a 3/4 inch gap between the top of the fridge and counter top.
