Flyfisher
I am replacing my 3 way Norcold refrig. with a new one. I am trying to figure out if I can improve refer performance by adding insulation to the wooden box that contains the frig. My question boils down to: What is the purpose of insulating the refer box? I have asked FWC and Norcold as well as others and can't seem to get a clear answer.
Do you add insulation to the outside of the refrig to further insulate the refer? One person said that could cause condensation to occur between the layers.
Do you try to insulate the box from the outside? (still have the air space between the refer insulation and the box insulation).
Or is the purpose of insulating the box, really just to occupy the extra space between the refer insulation and the wall so as to minimize the the amount of hot air from the refer that is allowed to circulate around the refer? This would seem to be the purpose of the fiberglass batting that FWC originally installed. FWC now installs mylared foil bubble wrap in their refer boxes.
Norcold's installation instructions seem to indicate that there should be between 0 and 1/2 inch clearance around the top and sides.
It is rather confusing.
