reico titan heavy duty jacks
Probably a good deal and I had some like that too, but when I got my RAM 1500 they wouldn't lift high enough to get my Eagle on and it was a very dangerous and time consuming job to get the camper on. I now have the jacks that mount to the corners even though I haven't take the camper off the truck (and don't plan on it). The cost of the mounted jacks isn't that much more.
I've had these jacks on an Alaskan for 25 years...loading takes about 15-20 minutes and they're mounted on the corners....my photo has them mounted, raised and stored in their loops
Alaskans cant use the vertically mounted jacks because the top rises with hydraulics ..the brackets for the Reico's mount under the bottom section...these are the THD's...much larger gears (2000# capacity each jack)
Reico sells risers for situations where the standard height isn't enough....I built 4 from older jacks I've got around so I can mount my CO on my 2003 F-250....I also needed the extra height.....
new...a set of these is around $800-$1000 depending where you buy them
For Alaskans...this is the most stable jack on the market
