Removable Outdoor Shower Mount
SD_Beaker
Dec 20, 2017
28
San Diego
As awesome as it is to have a hot outdoor shower, it's a bit inconvenient to have to hold the shower head the whole time. As I did not want to mount anything to the outside, preserving the 'clean' look, this is what I came up with.
The pictures are pretty self explanatory, but basically it hangs on the door when in use then just goes in the shower compartment when not in use.
I assume it will work for other models of 4Wheel campers as well as other campers.
To answer 'pvstoy', yes I changed shower heads. It does have an 'on and off' valve and works a bit nicer. Also, it used the same threads so no cutting was needed. Here's the Amazon link for it.
http://a.co/0tY59Un
