Removing Atwood LPCO detector
Bosque Bill
Oct 27, 2012
753
Albuquerque, NM
I suspect my Atwood LPCO in my 2013 Fleet has reached end of life.
Found a bunch of threads on problems with the detector, but nothing on the actual process of removing the unit for replacement. I can't figure out how to remove it.
The instructions say to insert a flat-blade screwdriver in the slot on the top an pry down to lift the flange off the alarm. That does nothing for me. Is there a trick to it? How far do I insert the screwdriver? How much to pry down? I've gone to the limit of what I think I can do without breaking the plastic and no luck.
Update: so I broke it off. No need to reply. I'd delete this post if I could figure out how.
