RV Lock (automatic door lock) for FWC
Bombsight
May 4, 2015
721
S.E. Texas
Anyone using one of these?
Might the rear door window frame be problematic when it comes to installation space?
So hoping it fits 'cause I hate keys!
www.rvlock.com
Hadn't seen these before, looks like a good idea. A little more than the myriad of other projects I have going will allow for now. Not sure if it's good thing or portends trouble that they have so many replacement parts available. I had put an electronic lock on the door to my workshop, one of the best things I've done. No more going back for the keys and/or leaving it unlocked (assuming I remember to shut the door...). Having the keyless remote would make it easy to double check that you locked things up as you head for an excursion.
Instead of mounting it in the door limited by the window, could it be mounted in the camper wall? Don't know if mechanism is ramped or like deadbolt.
It appears to have both so it probably only can be installed on the door, You're right, it couldn't be any wider than the existing latch because the window would prevent it
