screen door
BenG
Aug 28, 2007
148
wa state
ok I have a 86 keystone, it did not come with rear sceen door, can it still be added?, whats involved to add if it can, anyone one here done this? pics and suggestion wanted:)
yea, you might want to do a forum search
here is one thread I found on the screen doors ...
http://www.wanderthewest.com/forum/showthread.php?t=431&highlight=screen+door
usually the screen is built into the door, so to add the screen door later, you would need to get a new door that is a bit deeper and has the screen built in to it
but, check out the forum, ther have been some good ideas on aftermarket and home grown screen door ideas
Ben,
If your '86 keystone has the same door that my '84 fleet had
(Ben Burnett?), the current door w/ screen door FWC sells will fit right into the old frame configuration.Just pop the old door off at the hinges. I(we) did this, and apart from a little shimming to square it up, it wasn't to complicated ( for my buddy to do:eek:). The new door, with screen door attached, is a bit deeper than the one without screen.It should be pretty easy to trim out.
hope this helps.
TT
