SOLD -- 2015 Four Wheel Camper Fleet loaded $15K
MarnaAndShawn
Jun 29, 2019
5
!!SOLD!!
To the lovely couple from Durango Colorado!
AC/DC fridge
160 watt solar
Furnace
Sink
2 burner stove (both sink and stove are upgraded versions)
2 10 gallon propane tanks
2 AGM batteries
Side dinette
6 gal hot water heater(needs replacing - $800 Installed)
External shower
20 gal fresh H2O
Jack stands
Rear awning
In Colorado, Front Range.
We've loved it but have upgraded to a travel trailer.
Looking for $15k ($800 discount for H2O heater replacement) Happy to walk away with $14200.
Here's some pics-
Interested... Can you post up some pictures?
And which side is "front range?" West?
Some interior pics:
[sharedmedia=gallery:albums:1337]
And check this gallery for more exteriors:
[sharedmedia=gallery:albums:1336]
Here's some smart questions that have come our way:
1. Still available?
2. Looks like it might have tracks running the length of the roof? Yakima tracks? 160W solar panel(s) mounted up there?
3. Ditto, 2 roof vents?
4. Any details you can supply regarding the solar set up (e.g. charge controller, inverter, batteries)? Set up at the factory?
5. Any pics of the interior (sink, stove, fridge, electrics, storage, lift panels, fabric)? Any non-factory mods?
6. Does the front window open?
7. I presume if it's a 2015, it's got the 1-piece seamless roof, rigid foam insulation, black composite lift panels, factory-wired solar connections on roof and rear, pre-wired roof vents (if no existing fans)?
8. Any leaks or external impacts? Issues with lift panels, hinges, rear door or fabric/windows?
9. Don't suppose it has the arctic pack liner (?) ... if not, assume it's got the velcro around the top to attach one (?)
10. Can you supply FWC spec/build sheet? Failing that, snap a pic of the spec plate on the camper (w. build date, weights, etc.)? Build sheet would answer a lot of my questions.
And our answers:
1.Yes
2.Yes
3.Yes
4.Yes, factory install(see attached file for details).
5.See attached. No mods.
6.Yes
7.Yes
8.No leaks. Light hail damage to top. Took a couple of hits on the front side above open-able window. Basically road BBs. Nothing punctured. Rear door sliding plastic recently replaced. On rear side upper left to door, while carrying our bikes on a rear mounted rack, a handle bar grip made small indention, again, no leak. (See last pic). Side window can be a little sticky. One rear wall step has lost its spring and won't stay retracted. Looking for replacement online. $6+shipping. (Buyers Products
https://www.buyersproducts.com/product/folding-footgrab-step-762 )
9.No and yes.
10.Yes and yes, see attached.
