Redfish
$25,000
See the detailed condition notes below features and options.
Features and options:
*Note that fly rod vault and roof racks pictured in some photos are not included.
Comments on condition: Camper has only been used on extended 3-5 month trips in western NA and is otherwise kept in storage in our carport. No dents, dings or scratches on aluminum exterior and regularly washed and waxed. Tent sidewalls are in very good condition inside and out and have been regularly cleaned and treated with 303 Aerospace Protectant. Mosquito netting and screens are in excellent condition with no rips or runs. Interior walls, ceiling, cabinets, counters and table are in excellent condition with no scratches, dents, dings or stains. Upholstery is in excellent condition with no visible wear. Solar system was completely upgraded in 2020-21, with new battery cabling, breakers, switches, smart Victron MPPT solar controller and battery monitor, and new GoPower flexible panels wired in series (replaced under warranty May 2021). All components are in good working condition (solar, electrical, fridge, stove, faucet, water pump, exterior shower, furnace, water heater, fan). Batteries have been rarely drained below 70% and never below 12.4V. Camper is plugged into shore power while in storage.Minimal modifications (except for removal storage box), so interior and exterior are virtually the same as delivered from the factory. The very handy exterior storage box is easily removable with just 3 bolts/nuts and is attached to a frame that is bolted to the camper using existing attachment points, except for lower bracket which is bolted through the floor with a large backer plate inside a cabinet.
Also available:
$25,000
- Front dinette w/ swivel table
- Fabric upgrade
- 20 gallon freshwater tank
- 6 gallon hot water heater w/ outside shower
- Roof mounted solar— 2 x GoPower 100W semi-rigid panels wired in series (new May 2021)
- Victron MPPT 100/20 Smart Solar controller w/Bluetooth (new Dec 2020)
- Victron BMV-712 battery monitor w/shunt, display and Bluetooth (new Dec 2020)
- Exide 75ah AGM batteries x 2
- Bluesea Systems Automatic Charge Relay
- Isotherm 2-Way 65L compressor refrigerator w/small freezer compartment
- Flush Mount sink w/glass top cover
- Flush Mount 2-burner propane stove top w/glass cover
- 10 lb. propane tanks x 2
- Furnace with new digital thermostat
- LED interior lights
- Fantastic fan—variable speed w/ rain sensor and remote
- Extra roof vent (over bed)
- Thermal package
- Hypervent cushion (beneath bed mattress)
- Yakima tracks roof-mounted
- Screen door
- Mechanical camper jacks x 4
- Aluminum jack plates
- Rear-wall steps
- Custom removable and lockable rear cargo box & 2.5 gallon RotoPax (water or gas)
- Back-up camera (currently setup for 2016+ Toyota Tacomas)
- Upgraded door bolt lock
- Toyota Tacoma truck bed bars w/tie-downs and bed mats (for 6’ composite long bed)
- Portable folding steps, portable grey water tank, water hose, 30 amp pigtail for shore power
- Complete set of manuals for camper and all components
Also available:
- Boise Spring Works custom rear leaf pack designed specifically for 2016+ Toyota Tacomas carrying FWC Fleet campers (perfect set-up for campers that are mounted full-time)
- Free custom dolly for storing and moving camper in your garage or carport if you live anywhere near Gainesville FL
