Source for Battery Connector
Buzz
Aug 15, 2007
92
Anyone out there know where I can get more connectors like the one in the pictures? It is a two conductor quick-disconnect on my camper trailer battery. It's about 1 inch wide and 2 inches long. So far I've looked at RV parts websites, auto parts stores - everywhere but the right place.
Sorry about the low quality pics.
-Buzz
Hi Buzz,
I have a large local Napa store that has a lot of stock on hand. I can get stuff like that there in different designs. Mybe if you have a Napa there you can look in a catalog. If exposed to the elements look at a weatherpac setup (weather sealed).
Pic's are fine and get your message understood.
Free perhaps(??)
If you are looking for a connector which works with building wire (solid not stranded; 2 cond + ground) and is NOT weather-tight; I'll send you a couple, gratis. Email me at bobg333@ca.rr.com.
To: BOBG333
Thanks for the offer. I am still investigating my options.
What I would like to accomplish is this: I want to use the externally mounted battery on my camper trailer also in my ATC. In the ATC I want to charge it from the truck alternator and use the existing quick-connect to hook up to my inverter. Instead of wiring in an isolator, I will connect and disconnect the battery from the truck as required.
I may follow with the suggestion to use a more easily found connector.
I want to thank all of you for your help and suggestions.
-Buzz
I use a simple 3 pole AC male/female plug. It works great, stays connected on rough roads and muy cheapo. Are you sensing a trend here?
To: chnlisle
Geez! Sometime I just complicate things too much.
Thank you,
Buzz
