Kokopelli
Just got back from our first weekend in the camper with temps in the low 20's. I had installed the hunter digital therostat per Stans post. Set it at 58. Woke up very hot and the reading said 62 and it had "reset" the temp to 64. Reset to 50 and back to bed. Woke up later thinking we were in the desert in the summer - temp of 64 and it had "reset" to 68. Did I set something up wrong, get a bad unit, or what? It was driving me crazy.
Luckily I had brought the old suburban thermostat. So in the middle of the night I changed it out so we could stay cool enough. It worked well but the temp swing seemed to much that night with it getting warm up top before shutting off even set at the lowest level. Moved the dial in the thermostat to a shorter span and it cycled perhaps more freq, but not as hot before shutoff. Definitely didn't run too much, but then we have the arctic pac.
What do you all do to limit that heat buildup in the top bunk before the unit shuts off? Crack just the windows up top and front, crack the fan, both? It almost get too "stuffy" feeling just before the heater shuts off even set at the lowest setting.
Also did I remember someone mentioning a way to reset the low on the suburbans to 45 from 50? Couldn't find anything in the owners manual.
Thanks!
Thanks!
