Thermostat
I had the same problem with my Honeywell digital thermostat not working properly below 40 deg. Fan would come on but wouldn't ignite the burner. I called Honywell and they told me they are not designed to work below 40 deg. I have gone back to my mech style and I now have heat when it is in the 20's and 30's. Nice.
Humm.... interesting. I can't remember how cold it was when we tried it. I don't think it was below 40 but I'll have to check into that idea.
I tried the digital route too, but most of my camping is done in the winter with temps around 10 degrees to -10F. The digital didn't work at those temps so I went back to to original equipment. I wish someone would make a digital thermostat that worked when you really need it... When it's cold!
Just got back from a week long trip in the Sand Hills/White Pockets area. It got as cold as 17 degrees. Had a chance to try out the new thermostat extensively. I thought it worked great. We never set it below 50. Used up only one tank of LP. One thing I don't like, is the location of the thermostat. It it right next to the hot water tank and thus reads higher than what the actual temp is inside the camper. We have a secondary thermometer on the opposite side of the camper, near the window and it always reads about 10 degrees cooler.
One other issue that is beginning to bug me, is the seemingly continuous outside airflow coming into the camper from under and around the frig. I'd like to seal around it. Does anyone know any reason why not to do that?
The thermostat I added to mine reads "Lo" when it gets down in the 30s or so (I can't recall the exact temp) and when it does that it won't fire up the furnace. You need to warm it up first. In the past I've popped it off and tucked it in my shirt to warm it up then stuck it back on and it would fire things up. That was hacky and I'm getting ready to sell my Hawk now that my build is coming along so I finally got off my butt and just put a bypass switch around it. Now if it reads "Lo", just hit the bypass switch to fire up the furnace till it warms up enough for the thermostat to take over.
Sounds like a great "fix" for that problem.
Pods8, what do you mean by "bypass switch" my thermostat does the exact same thing yours does and having to take it off and wear it in your pocket for a few minutes is hokey. I like the sounds of your mod but don't understand it. Thanks.
All the thermostat is doing is closing a switch and making a connection for the two wires that are connected to it. I added a manual switch as well in parallel to the thermostat (from each of the two wires going to the thermostat there is now a branch at the end of the wire, one leg to the thermostat and one to the switch). Either of them closing will fire up the furnace.
Stepping back: Your furnace has 3 wires. Positive, negative, and thermostat. The first two should be obvious how they are wired up. The thermostat input just needs a positive connection applied to it to fire up the furnace, so there is a positive wire that goes from the power source through a thermostat and then to this furnace connection. The thermostat is just a switch that makes/breaks this connection to turn the furnace on/off.
Would it be OK to replace the thermostat with a on/off switch?
The furnace shouldn't care. I have no idea if there are codes it violates. Functionally it seems less than ideal though to solely use an on/off switch from a convenience factor.
What kind of fridge do you have, 2-way or 3-way? We have a 2-way and it is not open at all to the outside.
My Waeco 2-way has a 8" x 16" vent to the outside (rear drivers side).
There is even a manual switched frig vent fan to the outside.
It's a 2 way. There is a vent on the left side of the camper. Air comes in there and under the frig and into the camper. Should be easy to seal up around the frig.
I originally ordered my FWC with the fridge fan thinking it would be better for cooling. When you look at the build pictures there's an opening on the right side. However, when I picked it up they said the fan wasn't installed because it wasn't needed with the 2-way and the vent opening was sealed.
I pulled the fridge out to reverse the direction the door opened and there are no openings to the outside in the wall or cabinets. There's a vent grill on the right side where the vent would have been, but if you look under it, it's solid siding. You might want to check with Terry or Stan at FWC first, but I'd seal it up.
Interesting…I do have the fan installed. The vent is not blocked. It is a Dometic CR110. I'll give 'em a call. Thanks.
We were venting the Waeco's directly to the outside but as we got feedback about cold air returning to the inside through the bottom of the refrigerator, we have since closed that vent (it only acts as an access panel) and added venting slots above the refrigerator as shown in the picture.
From the horses mouth:
The Waeco CF80 will require ventilation. When the compressor is running it will create heat, the fan inside the unit will move this heat out through the external vents, if this air can't escape then it could cause the compressor to over heat or work inefficiently.
If you have any other enquires please get in touch.
Regards, .
__________________________________________________
Michael Ellis
Technical Officer
Dometic Australia Pty Ltd
So, what would be your advise now, on my install. There appears to be no room above my frig for a vent on the inside of the camper as your picture shows. Should I block off the outside vent, or put some weather strip around the frig from the inside?
I would just put weather strip at the bottom front of the frig to prevent the cold outside air from leaking in.
LIke this?
